CloudDriver
Oct 12, 2013Explorer
We have a 24 ft Minnie, same year as yours. Winnebago calls the solenoid that connects the house batteries to the alternator output the "Battery Mode Solenoid". I have replaced ours twice. Over time the solenoid sticks and doesn't pull in when the ignition is turned on, resulting in no charge to the house batteries when driving.
If you have a voltmeter, you can check the solenoid to see if the problem is with the solenoid itself or the wiring from the ignition switch.
Our Battery Mode Solenoid is located in an outside compartment, along with a number of breakers. The cover looks like this:
After removing the cover, remove the breaker panel. A word of caution here - there are lots of wires behind the breaker panel that have plus 12 volts on them. Be careful not to touch any bare connections to ground, or you will get an exciting spark (don't ask how I know).
The Battery Mode Solenoid is the silver thingy in the picture with two heavy wires and one light gauge wire. One heavy wire comes from the alternator and the other connects to the house batteries. The light gauge wire comes from the ignition switch. With the engine running, the light gauge wire and one of the heavy wires should both have alternator voltage - around 13-14 volts. The other heavy wire will have the house battery voltage. If the light gauge wire doesn't have alternator voltage, there is a problem with the circuit from the ignition switch. If the light gauge wire does have alternator voltage, but the house batteries aren't getting alternator voltage, the solenoid is stuck in the open circuit position. You might get the solenoid to pull in by tapping on it, but there is no guarantee that it would work on its own the next time you start the engine.
38,777 PostsLatest Activity: May 20, 2026
