dougrainer
Mar 26, 2021Nomad
Who is the maker of the window? Kinro/LCI or some other brand? When you state frameless, there is NOT an inside retainer ring that uses screws? Years ago, National had a brand of windows that did not use inside retainer rings with screws. There is a "rope" around the inside rubber lip and if replacing the old window, you can cut out the rubber from the inside, which allows the outside glass to pull out. You install the new window and push from the outside, PULL the rope from the rubber inside retainer and it flops around the inside of the wall and pulls it snug. I have never seen a glued RV window other than a windshield in 42 years as a RV service Tech. Doug
38,782 PostsLatest Activity: Sep 10, 2026
