strudeau
Mar 28, 2021Explorer
dougrainer wrote:
Who is the maker of the window? Kinro/LCI or some other brand? When you state frameless, there is NOT an inside retainer ring that uses screws? Years ago, National had a brand of windows that did not use inside retainer rings with screws. There is a "rope" around the inside rubber lip and if replacing the old window, you can cut out the rubber from the inside, which allows the outside glass to pull out. You install the new window and push from the outside, PULL the rope from the rubber inside retainer and it flops around the inside of the wall and pulls it snug. I have never seen a glued RV window other than a windshield in 42 years as a RV service Tech. Doug
All the windows in the Coach are Frameless. All of the windows, with the exception of the one I’m replacing, have screws on the inside that are spaced 4-6” around the interior of the window. The RV manufacturer sent me a new window to replace the fogged one in the door. I ve removed the interior door panel and have good access to the rear, and there are no screws. The only manufacture name I can find is Paragon. Again, this window is in the lower half of the door, below the main window. If it’s not glued in, I have no idea how it’s held in or what used to hold it in place.
38,782 PostsLatest Activity: Sep 10, 2026
