clotus's avatar
clotus
Fixed: Reverse lights not working
Hey all,
My reverse lights have not been working on my 2017 Winnebago Minnie Winnie 31K (2016 E-450 chassis)for about a year now. I finally have some time to trouble shoot it tomorrow, by myself.
I have already checked the bulbs and they are good. I will be checking the fuses tomorrow. Now for my questions:
1) If I put the ignition to "on" can I put the gear selector into reverse and will it send power to the lights without the motor running?
2) If it is not getting power, where is a common fail location I can check before I bite the bullet and re-run the wire
My multimeter is standing by and ready to solve this rather dumb problem.
Thanks!
  • Perfect, thanks for the fast replies. I will be working on this shortly and will post back.
  • Yes they work in reverse with the key in the on position but the engine not running.
    Check for a bad ground connection at the lights; that is a common fault and one sometimes tricky to diagnose if you are not specifically looking for it.
  • They should work with ignition on, engine off, BUT set parking brake!!
    In order I would check- Bulbs/sockets, fuse, back up switch and switch connection.
