dougrainer
Mar 23, 2021Nomad
If you have a Heart/Trace/Xantrex system. Disconnect 120 power to the RV. Disconnect the Large 12 volt positive cable to the Inverter. let sit for 15 minutes. Reconnect the Battery cable and then reconnect 120 to the RV. That resets the Inverter and your problem should be gone. Doug
38,776 PostsLatest Activity: May 14, 2026
