Tinstar wrote:
A TPMS could have helped but I doubt it. I'm reasonably sure it was fully inflated when I pulled up to the light. I had to slowly roll forward as I approached the light and it was as smooth as silk. When I pulled away at the green, the tire had not made one rotation before I knew for sure it was flat. I would bet there was something in the roadway at the light and I got it, loosing air while I waited for the green.
There won't be any warranty reimbursement I'm sure. Driving on it for 150 yards to get out of one of the busiest intersections in Denton didn't do it any good. I'll see when I replace it if the tire guy can determine what it was.
Tinstar,
Yeah, a TPMS most likely would have notified you that you had a problem. But, I'm wondering something here. You state you were rolling just fine, silk as could be, right up to the point you stopped at the light. But, the INSTANT you started to take off from the light, you KNEW you had a flat tire, correct?
Now, unless you had your music up to TEEN-AGER-LEVEL and your wife was disco-dancing on the dash, don't you think that you should have heard the 100 psi. instantaneous blow out, while sitting at the stop light, based on the fact that you said the ride was flawless up to that particular spot??? I'm certainly not chastising you here. Not at all.
Did you have any pulling of the front end, especially during braking, or any other even remote ill handling effects prior to the stop? If not, then the air escape had to be pretty near blowout speed AND NOISE VOLUME, in my opinion, at that stop light. This is all just surmising things here.
And, since we're on the subject of changing your own spare on a diesel pusher. About 99.99% of the lug nuts on those Diesels are on with usually around 450 ft. lbs. of torque, correct? May I ask, your procedure for breaking them loose and all that? This is really interesting to me. I carry a "Torque Multiplier" on board that allows me to break all 10, 450 ft. lb. lug nuts, with one arm, while sitting.
But, that really doesn't do me any good since I don't carry the spare. I would only use it if, we had a blow-out and, was anticipating Road Service sometime soon. That way I'd just speed up the tire changing process.
Scott
