j-d
Jun 19, 2018Explorer II
Wrangler is 4x4. To tow an AWD or 4x4 is All or Nothing. Either four-down "flat" with Tow Bar if OK by manufacturer, which Wrangler is, or four-up on a Trailer. If you wanted to use a Dolly for some reason, you'd have to drive the front up onto the Dolly, then slide under and disconnect the Rear Drive Shaft. Not what you want to do RVing... If you had a dolly and needed to transport a Wrangler someplace one time, dolly and pull drive shaft would make sense.
38,769 PostsLatest Activity: Apr 04, 2026
