lostdog
Dec 25, 2013Explorer
JimM68 wrote:
X3, but, always check in your owners manual under "recreational towing", the specifics for your vehicle will be there.
The owners manual on the 2013 year model is in error as explained by factory reps. No need to pull any fuses. That was for older models that still had a steering wheel lock and the keys was to be left in the ignition and turned on so the wheel would turn. If you have NO steering wheel lock there is no need to turn the key on.
Hook up...plug in lights...transfer case in neutral...transmission in Park or some gear...pull the keys and drag it away. We have nearly 13000 miles dragging our 2013..don't even know it's back there.
38,782 PostsLatest Activity: Sep 10, 2026
