StaceyH1977's avatar
StaceyH1977
Flat towing with my Class C
I was torn as to which forum to put this in but since the question is more regarding how the motorhome will do I decided to put it here.
I have a 2016 Coachman Freelander, 33', Ford Chassis with the V-10. I currently have a 2014 Grand Cherokee Summit which weighs in at about 5500 lbs. So, is within the weight the RV can pull, rated at 7500 lbs. I have the opportunity to trade for a 2015 Jeep Wrangler Unlimited which weighs around 4300 lbs.
Is the difference of 1200 lbs going to make a huge/noticeable difference when it comes to pulling a vehicle? In your opinion, would you prefer to pull the Wrangler over the Grand Cherokee?
Thanks!!
  • The hitch on my 2016 Jayco Redhawk 29XK (32 feet)class c is rated for 7500 lbs.
  • The larger mud tires on the Wrangler might negate the lower weight, at least when pulling. It might push less when braking however.
  • DrewE's avatar
    DrewE
    Explorer III
    ron.dittmer wrote:
    If you end up towing the 5500 pound vehicle, you will be over the rating of the hitch which is 5000 pounds for just about every class C. It used to worse. Most older class C motor homes made prior to 2005 were equipped with a 3500 pound hitch. I have not heard of a class C with a hitch rated higher than 5000 pounds. You will want to look into that before making a final decision.
    According to the Coachmen website, the current Freelander models built on the Ford E-450 chassis do come equipped with a 7500 pound hitch. I assume they upgraded it when Ford upped the GCWR spec for the E450 chassis.
    I think there are a few other class C's (on the E450) that currently offer a 7500 pound hitch as standard. Of course, many super-C's also have similar or greater tow capacities, but that's a different matter entirely.
  • We used to tow a 2100 pound Toyota MR2 Spyder. We then switched to a 4100 pound Jeep Liberty. The 2000 pound difference was very noticeable. That does not mean it's a problem concerning power. The concern for me was braking so I got a good tow brake kit and all is well.
    Don't skimp on a tow brake. There are some great kits available and some that are marginal. Ours in our Liberty is a permanent installation which maintains vacuum in the power brake booster so the cable driven braking solenoid is much more effective. Also with a permanent installation, there is nothing to see and nothing to fuss with. The only matter at hand is that it is difficult to remove and install in a replacement tow vehicle.
  • Definitely noticeable. you're not talking 300 or 400 lbs. you're talking over 1/2 a ton.
  • More than a thousand pounds less towed weight will be very significant.
