Cbones
Aug 08, 2013Explorer
The first thing I would definitely recommend is joining the Discovery Owners Association. They are a very large owner group with tons of information. After that have the motor checked for exhaust leaks especially the exhaust gasket which seems to be a common issue as well as radiator failure (leaks where the tubes connect to the side inlet tanks on the bottom corners). Short of that they are pretty good coaches. They are usually neck and neck in total numbers with the Phaeton as being the number 1 produced mh. Both are great coaches, and if the floorplan works, go for it. I can personally tell you that Fleetwood is a great company to deal with. The parts and tech support personnel are superb. Make sure you get somebody knowledgeable and trustworthy to give it a complete independent inspection. Good luck with your choice.
Disclaimer: I own a 2010 Discovery
38,782 PostsLatest Activity: Aug 31, 2026
