-Gramps- wrote:
Could be but where is the question, an inline fuse should be visible. Maybe a loose wire or broken connection between the relay and the motor? The slideout could have broke itself by grabbing a wire coming in or out.
Yeah, I've been "playing" with the slide issue for a couple weeks now. I just bought the MH in November. I'm working on "making it mine". Not really getting in any rush, or getting frustrated in finding the problem. Been doing lots of other things to the coach, ie figuring out the tv/antenna system (still haven't), changed engine belt, working on the Sleep Number bed, etc.
The circuit board has 2 fuses on it. One is a self-resetting, 15 amp breaker, the other is a 20 amp slo-blo barrel fuse. I'm figuring the 15 is for the coils in the relays, and the 20 is for the load (motor). I haven't checked them with a meter yet with a load on them.
I have the slide out now, and have full access to the wiring. Absolutely nothing looks out of place (pinched). All the wires are in the plastic conduit, still with the factory tape & ties in place.
Oh, BTW. I did spy another bank of fuses (12v) last night. Didn't have time to check them, or see what they go to.
