bodomalo's avatar
bodomalo
Fleetwood Fiest 12V outlet near TV - no power
Hi
I have a 2006 Fleetwood Fiesta 26y.
I tried to connect a 12V Fan to the 12V TV outlet back in our bedroom, but it is not working there (no power).
Does anyone know where I can find a wiring diagram for that, or which fuse might cause the problem? Or is there a simple ON/OFF somewhere for that outlet?
All other 12V or 120V outlets are working.
Also in the front storage above the passenger seat, where the TV antenna is connected, there is a ON/OFF Switch next to that (and 2 120V outlets). It does not say anything, any idea what that ON/OFF could be for? (it is very thiny one, a green LED goes on next to that switch if it is ON)
Thanks
Bodo
  • The fuse should be ok, I switched it with anoter working 20A Fuse.
    Still no power there.
    @ljr869 - I think I can not reach the back of that outlet. It must be somewhere in the bathroom behinde a closed area.
  • Check the back of the outlet, it may not be hooked-up. That's why mine didn't work.
  • Check the 12V DC fuses near your power converter panel. Usually next to the 120V AC breakers.
    The on off switch is to switch on/off the antenna booster power. On for OTA TV, off for cable TV.
