donn0128
Nov 24, 2014Explorer II
CONverter changes 120VAC to 12VDC
INverter changes 12VDC to 120VAC
With no noise inside you should hear the fan running. Also the converter might be behind the breakers. No DC voltage could mean bad battery, bad converter, blown fuse or several other things. To check anything you really need a volt meter and understand how to use it. Volt meters can be had lots of places for under 25 dollars.
