nadia's avatar
nadia
Fleetwood Flair 31A
My parents are looking to purchase a 2004 Fleetwood Flair 31A, does anyone have any experience with this RV? Any pros or cons or general feedback would be very much appreciated
thank you!
  • Thank you all for taking the time to reply and your feedback, it is very helpful
  • The OP said it is a 2004. It is either a Workhorse or Ford. It is also either a V10 or 8.1L. Ford was a rougher ride at that time. Workhorse was definitely the better chassis than for ride and service. It could have an Allison trans. if it is a WH chassis. That would be a huge plus. I almost bought a Flair when they first came out. Watch for any delamination in sidewalls and any roof leaks. That is any chassis from that period.
  • 2000 Fleetwood Flair/v-10 engine/F-53 chassis/30'
    We traded our 1991 Bounder for our current 2000 fleetwood Flair,Love it and have had good luck with Fleetwood products-My recomendations would be Ford Chassis compared to P-30-- -V-10 over 460 motor---check tire dates expensive part of MH is tires---Ford chassis do cheap fix and add rear track bar---Shower across the hall from potty room was important to us & no slides was important---Rich
    Pics at pauperspride.blogspot.com
  • I just bought a 2004 Fleetwood Flair 33r in April. Great class A.
  • It comes down to a detailed inspection and how well
    it is maintained. Im on my second Fleetwood. Not
    The Best or worst. You get what you Pay for.
    Insist on seeing the récords.
    Bob
  • What chassis? Workhorse has problems with brakes. Recall is in effect. If rig is on recall list it should be done immediately.
    Some years of Ford has problems with the spark plugs seizing on removal and breaking off. First plug change should be done by dealer which I do not care for.
    Have them check to see if there is maintenance records available.
    I have had good luck with my Fleetwood product.
