RLS7201
Dec 19, 2019Explorer II
jaycocamper62301 wrote:RLS7201 wrote:
Your system is set up from the factory to charge all batteries from all sources. You do not have a BIRD or do you need additional devices.
Most Non-Fleetwood owners do not understand your system.
Your 200 amp isolator relay is not functioning. Seeing how the relay is not functioning from the circuit board, in your BCC, or the emergency start button. I would guess the relay is bad.
Or you could have a bad connection on the control wires to the isolator relay. Look at the wiring print on the inside of the BCC (Battery Control Center) cover. It's really pretty simple.
Richard
Are the relays built into the board in the BCC because there is just a coach battery disconnect and a Chassis battery disconnect and 2 circuit breakers behind the control board?
The isolator relay on your coach will be close to the battery banks. One each large cable from each battery bank and two small control wires. It is larger that the 100 amp silver relay in a previous post.
Richard
38,782 PostsLatest Activity: Sep 02, 2026
