zette's avatar
zette
Help...
I have a 92 thor pinnacle q340 . I can't find where my ATS box is located. Please someone tell me?
  • I’m taking a shot in the dark here because I’m not sure what you are describing and what you have already checked. But if your RV is plugged into a pedestal and you have no power in the RV, it could be your power cord. While plugged into the pedestal, use a multimeter and check the voltage at the breaker panel on the ends of all 3 (4?) legs of the power cord (or at the transfer switch if you have one and find it).
  • Easy to post a picture or two on this forum. That would help too.
  • Are you sure you have an ATS? Many RVs into the 90's used the shore power cord to plug into the generator. You plug in your shore power to a pedestal or into your generator. "if" your RV has an ATS, it would be in the bin with the generator or an adjacent bin. It needs to be pretty close to the power source. How long have you had this RV? Are you having an issue and if so explain it. It may not be your ATS. No power with the genny running could simply be the breaker on the generator itself. The more details you provide, the easier someone can try and help you.
    • zette's avatar
      zette
      My generator fell and I lost my 110 power I have power going out the outside pedestal but nothing working.all breakers and fuses are good
      • way2roll's avatar
        way2roll
        Trailblazer
        Still pretty cryptic. What do you mean "fell"? As in physically fell out of the RV? Due to rust, frame failing? If that happened there is likely a host of electric issues it tore in the process. Almost impossible to armchair diagnose this. If your supporting structure is bad enough to allow the generator to fall out of the RV, then I would guess there is a lot of corrosion or physical damage and wires and grounds etc. are not getting good contact if at all. This is all a guess because you haven't provided any real details. I would recommend calling an RV tech to come take a look at it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
