j-d
Mar 07, 2018Explorer II
You seem to want a mechanized/automated leveling system. That said, consider Bigfoot
By all means, find out the weight of the complete system you're considering. You might be able to find "shipping weight" but if you can, get the weight of each main component. The Four Jacks, and the Power Pack. Add say 10% for hoses, wiring, and such. Then see if you can live with that loss of carrying capacity in your coach.
I suggest Bigfoot because they have the best reputation among the levelers commonly discussed on this forum.
Now, as to "Lightweight Alumium." Yes, it's lighter than steel. BUT it takes more aluminum (diameter, thickness, cross section) of individual parts to provide the same strength as steel. I see this with tow bars. The "aluminum" ones are nice, and they're pretty, but the actual weight isn't that much different from "steel" ones. That's partly because of how much more aluminum is required for strength, but also because other considerations require many of the parts to still be steel. I'd be very surprised if the pump motor in an aluminum system isn't steel. Maybe the jack cylinders are aluminum, but the pistons are probably still steel.
Welcome and good luck!
EDIT: Bigfoot seems to have a promotion running on one of the three systems available for Sprinter MoHo's... Midrange system for less than the basic one.
38,782 PostsLatest Activity: Sep 21, 2026
