IAMICHABOD
Jun 22, 2017Explorer III
When I was looking for my RV, 2002-2006 Fleetwood Tiogas the dozen or so that I looked at, 75 percent had non working outside stereos,most were from water incursion, Some were just a blown fuse. That is where I would start.
Located behind the door to the fuse panel below the front facing dinette seat.
Click For Full-Size Image.
This my fuse block on my 2006 Tioga.
Located on that door inside, is this.
It will tell you which fuse goes to what,that is where I would start,check each fuse and pull each connector and reset.
