- werni9ExplorerThank you for your comments.
- rgatijnet1Explorer IIIFrom underneath, I was able to remove both arms and then just tipped the sofa on it's side and slid it out the door.
- cableguy574ExplorerHad to remove the matters the bed frame and saw the rest of the frame to get it out the door
- the_bear_IIExplorerSome RV'ers have removed windows if the doorway isn't large enough.
If the back comes off then you should be able to get it through the door.
If the back lays down then you should be able to get it through the door.
And/Or take the sofa apart as much as possible including removing the bed mechanism. This makes it easier to handle the sofa.
38,778 PostsLatest Activity: Jun 10, 2026
