hanko
May 21, 2015Explorer
Ok let the arguments begin. Will you define flickering, one could mean dimming as flickering. Jeff an incandescent light bulb certainly can appear to flicker as you say. In my 40 years as an electrical contractor, I've seen many different situations that could be considered flickering. An inductive load starting can makes bulbs appear to flicker, bad connections, In this case I thing the OP should isolate the converter charger first
38,782 PostsLatest Activity: Sep 10, 2026
