filadelfia
May 22, 2015Explorer
AS pusherpilot mentioned in his reply, it may be the 12 volt cut off relay aka salesman switch that is causing the lights to flicker. A quick and easy test to determine if the cutoff relay is the problem is to place a jumper between the two large red wires attached to the relay and see if the lights stop flic
Good Luck Don
Good Luck Don
38,782 PostsLatest Activity: Sep 10, 2026
