rgatijnet1
Apr 26, 2015Explorer III
I installed the engineered flooring that resembles tile in our coach. It is the floating type flooring with an 1/8" foam backing. We travel quite often in the Winter and have been in below zero temps and above 100 degree temps. We have had no problem with the flooring buckling but I was careful to allow the recommended space around the perimeter for expansion. I also followed the directions to attached the trim molding to the wall rather than down through the flooring material.
After I stripped the old carpeting out of our coach, I put two coats of polyurethane on the sub-floor to seal it from any future spills/leaks.
Basically it is very simple....follow the manufacturer's recommendations and you will have no problem.
