ThruTraffic
Sep 12, 2020Explorer
Flying Floating Flooring
Have any of you ever installed floating flooring in your RV and glued it in place?
No need for hundreds to pile on with the mfgr said this and that and no you can’t do it because the warranty is gone and yada yada yada. I know one isn’t “supposed“ to glue floating floors.
I’m asking in this context:
- Floating floors are designed to float because of expansion; the reason a 1/4” gap is left around the perimeter.
- BUT, is expansion really an issue in such a narrow installation like a motor home??? The widest part of my RV’s floor is about 6’.
I understand the necessity of considering expansion in a home with a large room. But what if one were simply doing a four foot wide hallway; which in most cases are around three to six feet wide. If one could glue a hall, one should be able to glue in an RV.
I don’t think the weather extreme argument holds or the manufacturer would warn against installing their products in vacation homes where inside is like outside when no one is in residence and then fired up the furnace/AC a few times a year.
I’ll add a line or two about why I’m asking: I’m concerned that the rollers on the slide out may push the flooring ahead of it, and the worst case scenario would be when they push the flooring till it stops against the far wall it could then push the flooring until it “accordions”. When a roller under load is given enough inertia to move it has to be forced to roll; it doesn’t want to by itself; it digs in like a kid being pushed towards the bathroom to brush their teeth, then it will roll. If the floor is glued this concern doesn’t exist.
