msmith1199
Jul 19, 2016Explorer II
skrams wrote:
Since laminate comes in a lot of different thicknesses, how do you know what one is the right thickness for your slides? I've yet to find out, and since carpet compresses, I can't even use that as a guide.
Pull the carpet out and then see what you have. My slide doesn't even touch my carpet and assume there must be a pad under it. So I'm confident I could put most any thickness laminate down and not have a problem. I haven't done it yet, but I'm going to. I'll probably pull the carpet out before I buy anything just so I can make sure how much room I have to work with.
38,782 PostsLatest Activity: Sep 10, 2026
