howdy35
Sep 25, 2015Explorer II
I changed out some of my light fixtures like Executive did with LED strips purchased from Amazon. I used four strips on the lights in the kitchen and living areas and put two of them on the ballast cover as well as the other two inside the light. The stickum of the double sided tape and the LED backing wasn't working well when I put mine on and so I used some Goop. Stuck just fine. I have three more to go so I agree to buy plenty supplies if you are going to do the whole MH as I plan to do. Also it is easier if you determine the + and - on the LED strips before installing. Just make sure to put connecting wires on the correct end after the first cut. I went another step in that I soldered the LED connecting wires together before installation in the coach. Before that I found some weren't lighting because some of the wires pulled out during installation. No more buying bulbs when the ones I took out are used up. A fairly easy task but tough on these old shoulders working overhead. Best of luck on the changeover
38,771 PostsLatest Activity: Apr 15, 2026
