dougrainer
Oct 02, 2013Nomad
Davidlatham2012 wrote:
HWH actually makes there own fluid. If you have none you can use transmission fluid. Its all hydraulic fluid.
HWH does NOT really make their own fluid. ALL Jack systems use transmission fluid. HWH fluid IS Transmission fluid without the RED dye. They purchase it without the Dye. The reason is, in slide room application, if there is a leak, better to have clear/gold fluid inside than a red dye. Doug
38,777 PostsLatest Activity: May 18, 2026
