theoldwizard1
Feb 09, 2021Explorer II
Another drop the pan, change the filter and replace what came out. I recommend using the OEM transmission fluid.
I like Pristine Radiator Flush. I do a double rinse so I know there is no old antifreeze left. Because you can never really drain a cooling system I always use full strength coolant. Always check the level and strength after driving for at least 30 minutes and letting the engine COMPLETELY cool down.
38,782 PostsLatest Activity: Sep 18, 2026
