jimj's avatar
jimj
Looking for Transmission cooler radiator 03 Diplomat
I have developed a leak in the tank on the tranny cooler. I have had it welded twice so that isn't working very good. It is getting a crack in the tank in the same place and the weld isn't holding. I don't see any stress on it in that area but maybe the vibration is breaking it.
If anyone knows of a source for the older Monaco parts please let me know.
The radiator is 12" x 22" Aluminum and mounts on top and r side
I could try another weld job but would like to replace it.
Thanks for any help
JimJ 2003 Diplomat
  • Just a followup on the transmission cooler radiator leak. The tank developed a leak for the second time, first time was 2 years before, I removed it and had it tig welded at a machine shop and it looked good but it developed another leak after around 400 miles so filled up with tranny fluid @$52/gal and limped to my destination. Took it off again, getting pretty good at this, took it to a machine shop and explained where it was splitting and that I wanted a patch welded over the corner where it was leaking. They Tig welded the crack then welded a patch over it. I think it will hold only time will tell.
    Thanks for all the helpful replies but I was forced to get it done quick so the patch job.
    Thanks
    JimJ
  • Radiator Supply House in Sweet Home Oregon can make any size and type of cooler.
  • Source is a good choice but if you take the measurements to a Radiator shop in your area they can match it or order it built.
  • None of the RV manufacturers made their own oil coolers. They all use standard sizes that are available. I'll bet that any radiator shop could find a replacement based on the size and the number of rows of cooling lines.
  • MountainAir05 wrote:
    Source Engineering inc. Coburg, Or. rv-chassis.com 541.935.0308
    OEM supplier for radiators and CAC's
    Phillip Cochran C,G & J Inc Heat Transfer
    Brice Thomas Radiator
    256-546-4613 work
    256-312-2828 cell
    www.cgj.com
    https://radiatorsupplyhouse.com/
    You may never get a better answer then this.
  • O sorry I thought I made that clear it is a separate radiator for the tranny. It is 12"x22". I am looking for a replacement.
    Thanks
    JimJ
  • Source Engineering inc. Coburg, Or. rv-chassis.com 541.935.0308
    256-546-4613 work
    256-312-2828 cell
    www.cgj.com
