rivercity22ExplorerApr 18, 2014Foam in water after de-winterizingFor some reason I'm getting foam from the kitchen sink on the cold water, bathroom faucet seems normal. I never put the water filter back in, could that be causing this?
MocoondoExplorer IIApr 18, 2014Anti-freeze usually causes the water to foam. Run enough through and it will eventually go away.
Related ContentWinterizing/de-winterizing water heaterDe winterize ?De winterizingde winterizingVery confusing water issue - not flowing to some faucets after de-winterizing
