jeffcarp
Apr 19, 2014Explorer
The faucet aerators make this "foam" worse. It isn't really foam. It is just air bubbles. If you can unscrew the aerator (careful not to lose any gaskets down the drain) you will likely see that your water is running clear. Another way to see is to run the water into a cup or the palm of your hand and see what it looks like. Foam will remain for awhile - air bubbles will not. If it is air then don't worry about it.
38,766 PostsLatest Activity: Jan 10, 2026
