Vt_Rv's avatar
Vt_Rv
Fog light replacement
I need to replace one of the fog lights on my Damon Challanger. The old light is a Hamsar H289. I can't find one anywhere. I've been to several auto parts stores and scoured the Internet and I'm not finding the housing with the same connecting bracket.
Ultimately I'd like to swap them both for a brighter led or hid version but not sure if it's as easy as finding a set that will fit in the hole and splicing wires.
My current lights use halogen 893 bulbs.
  • I ordered a set of Westin lights that I'm hoping to make work. It looks like a similar bracket so we'll see.
  • If you do find some that will fit,Yes its as easy as mounting and splicing the wires, correct polarity +_+ -_- at least for most leds. I did the same on my older MH .. no problem.
  • I also needed to replace my Hamsar foglights due to broken lens. I looked at replacing it with an off the shelf light from an auto parts store but could not find one that fit in the slot in the front facial of the motorhome. I contacted Hamsar and they found a warehouse that still stocked their, no longer in production, foglights.
    Hamsar Corp.
    Good Luck
