Has anyone had their side fogged windows repaired in Ohio. My Driver Side Window is fogged and needs repaired. Looking for someone to remove from Motorhome, repair and properly reinstall.
I was able to order a replacement pane from Atwood for mine and did the replacement myself. Brand new pane, shipped to my front door was less than $200.00.
Having never done the job before, I found it to be a little involved, but definitely do-able. Removed the retaining ring inside the coach while my wife held the window. Removed it, took the frame apart, replaced the bad pane with the new one and put everything back in place. All in all, it took about 2 hours to do.
