Kidoo
Oct 21, 2014Explorer
Fogged up window repair
My window is badly fogging on the top window on the driver side. I talked with a guy that repairs fogged up window on house but he says he cannot do it on a RV because they are hardened windows and the could break in pieces. The distance between the two pane is also too small and it is dangerous to pass through on the other pane.
To repair house windows, he drills a hole on top and bottom, spray some cleaning materiel in it, flush it and seal the holes with a little valve and it works pretty good, he makes good money on this easy repair. He does it with the window in place.
He told me that I could take the window out and drill a small hole at the bottom and one on top, just between the dual pane, not in the window like on a house, carefully! Maybe one hole each side too, and reinstall the window. It should clear up by itself as humidity will flow out.
Anyone tried this before?
