busyguy
Dec 23, 2014Explorer
I just got done helping a friend with his fogged windo. It is on an AlfaSee Ya 40 ft M/H. We took the window out took it apart cleaned the glass and replaced the seal between the glass. All together it wasn't to bad of a project. Just time consuming and exasperating trying to get the glass back in the rubber seals and into the frame. The window is very heavy and needs 2 people to remove and replace.
It took us old guys about 8 hours from start to finish. That included the 3 hours for the fill glue to dry. You can do it if you have some help.
We order the window kit from Dave Root in Oregon. It will have all the stuff you need. You can get the urethane glue at a auto glass shop and order the seal from amazon. Lots cheaper.
Busyguy
Busyguy
