mobilefleet
12 years agoExplorer
well I ended up doing a DIY fix that worked out well. I removed the window from the rv and placed it on sawhorses. Then i taped up the inside pane completely with duct tape, and took a center punch and tapped it a couple times, hard enough to shatter the tempered glass. It pulled out with the tape leaving just a few pieces to vacuum up with the shop vac. It apparently had been fogged quite awhile as the outer glass was etched and would not defog with just window cleaner. I took some very fine grit sandpaper (1500 grit) and wet sanded the glass lightly. Followed up with turtle wax rubbing compound applied in a straight line motion instead of circular. Wiped clean with a damp paper towel and it looks great. Finished by removing the worthless rubber gasket around the frame and applied pro flex sealer instead.
Hope my experience helps someone else
38,781 PostsLatest Activity: 13 hours ago
