J-Rooster
Jul 01, 2014Explorer
JCMack wrote:You will probably be alright! Check regularly for awhile to keep an eye on things!
Just to update everyone on our maiden voyage problems. First to all thank you for your comments. There were no visible oil leaks under the motorhome. The tranny was down 6 litres of oil and maybe it was never filled properly when I had all fluids changed shortly after purchasing the unit(less then 800 miles on unit since change out). The MH has know been towed to a garage near home at considerable expense, and I will keep you all posted as we learn more. Two more thoughts before I go. Should the tranny not of alerted me It was low on oil and second shame on me I did not check fluid levels prior to leaving,lesson learned. Wondering if low tranny oil is just a coincidence and the problem is something else?
38,756 PostsLatest Activity: Oct 21, 2025
