glamisorbust
Nov 07, 2014Explorer II
They will just tell you that you'll have to run new wires from front to back. Hardest part was trying to figure out how to get the wire from under the dash through the firewall. I used a coat hanger and pierced through the foam they spray around the wires once they are installed. Looks like a big chunk of foam if you look in the generator bay up front. Used the coat hanger to pierce through that foam from the inside, and I taped two heavy gauge wires to that and pulled them through. Then got underneath and pulled 45' of wire through the frame rails and zip tied it all up. I do not have a hot wire for my crv. I am probably gonna add a battery cut-off switch to it so I can pop the hood and disconnect it.
38,766 PostsLatest Activity: Jan 10, 2026
