You will probably get closer to 6 MPG with such a heavy RV. I get about 7 MPG with my 16,000 pound RV with a 460" V8, the factory rating on mine is only about 225 HP at 3,600 RPM. The V10 revs up much higher, and can run 4,000 all day long. Short term at 4,500 RPM would be my limit - it is a large engine. Running it much higher than 4,000 RPM will cause mileage to drop a lot.
11 MPG is a stretch - even the smaller height class C, that is more aerodynamic and they do not get that good of mileage. It might be possible in a 12,000 pound class C, with the V10 and no cabover section that tends to create more wind drag, if the driver is willing to go no more than 55 MPH, then it might get 11 MPG.
But modern gasoline leaves a lot to be desired too. I have found that I get worse mileage just because of the alcohol that has been required in gas for years. It lowers the BTU's per gallon, and thus you get worse mileage.
Fred.
