Wow thanks much. I have an OBD 1 tester. But I could never find the location of it. I will for sure look in these areas mentioned. Never dreamed it to be under the doghouse.
On a good note I think I have found the culprit. I will know more tomorrow but I think it is out of gas. My tank may have been tapped into. I went around to the drivers side to unplug the motoehome and as usual I always by habit twist the gas cap to make sure it is tight like it should be. Low and behold the cap had been removes and just laid back over the gas tank nozzle. not screwed on at all. I went and picke up 5 gallon of gas and poured in it and turn the key on and it kicked off immediatly like it always have. I will go gas her up tomorrow and check this theory out. I'll let you all know.
anyway thanks so much for the tips. I appreciate it.
Dad
