Ok here is some more info. In my 1996 ford Chassis Book it says my Motorhome has an OBD II system. Where do I find the connection for scanning the system. I have a scanner and that should tell me whats going on in most case.
Went out this mourning and it kicked right off and set and idled for several minutes. Run smooth with no issues. Ran for probably 5 minutes and Check engine light and Battery light came on and it died very quickly. Almost like turnining the key off. I'm going to do the spark test now and will get back to you.
But if anyone knows where the OBD II connector is please let me know. The book does not tell me.
Thanks so much in advance.
Dennis
