STBRetired wrote:
If your transmission cooler is inside the radiator, install a separate one and don't use the one in the radiator. The trans will put a lot of heat into the radiator when under load like towing of climbing hills. Your trans will be happier too. Check your trans fluid to see if it is darker than normal and if it smells burnt.
On the OP's coach, not using the trany cooler in the radiator is a very bad idea. The OP's coach has 2 tranny coolers. The first one is air over oil and the second one is coolant over oil. The second cooler/heater helps keep the tranny up to temperature in cool weather. Ford engineered it correctly.
Richard
