lawrosa
May 25, 2018Explorer
timmac wrote:kerrlakeRoo wrote:
Check your manual, that seems way low.
I just looked and got numbers ranging from 16.5 to 20 depending on exact year.
I did not flush the whole transmission, just drained from the pan and refilled, I had it flushed 2 1/2 years ago, just removing some of the fluid and refilling, plan on doing it again since I have 12 quarts but I cant remember what the pan itself holds, my oil drain pan holds only 7 quarts so it did not over fill.
Its 8 quarts in the pan. Those trans have internal t stats so flushes are difficult.
You should of known how many quarts by what you removed....
