timmac
May 25, 2018Explorer
lawrosa wrote:timmac wrote:kerrlakeRoo wrote:
Check your manual, that seems way low.
I just looked and got numbers ranging from 16.5 to 20 depending on exact year.
I did not flush the whole transmission, just drained from the pan and refilled, I had it flushed 2 1/2 years ago, just removing some of the fluid and refilling, plan on doing it again since I have 12 quarts but I cant remember what the pan itself holds, my oil drain pan holds only 7 quarts so it did not over fill.
Its 8 quarts in the pan. Those trans have internal t stats so flushes are difficult.
You should of known how many quarts by what you removed....
Well I still have the old fluid in the drain pan, I thought it only holds 7 quarts but I could be wrong and it is almost full, I guess I could pour it out in the empty quart bottles and see what I did drain, its going to be messy but at least I will know the amount.
Thanks
