Harvard
May 30, 2018Explorer
Let me explain, a "generic alignment" is a "tweak the toe and you are good to go" alignment off the production line. That is the same alignment you will get from the "Ford Truck Center" with the complete RV build after ownership.
Mean while the driver gets to fight with a wandering beast that has only 3.5 degrees of caster AFTER having the full official blessing from the front end (production) to back end (dealership) of the "Ford Motor Company".
We should be able to take our Ford E350/E450 RVs into a Ford Truck Center and have the caster changed from +3.5 degrees to at least +5.5 degrees for safety reasons. Period. It does not happen that way, the dealerships hide behind the +1.5 to +7.2 caster specification.
JMO
JMO
38,766 PostsLatest Activity: Jan 10, 2026
