I'll just add that if you have an older MH on a Ford Chasssis "REPLACE" the brake lines.
I lost brakes exiting an interstate and almost died. Only to find out it was the brake lines. I had JUST had new brakes put on the previous week! Mechanic said everything else looked fine.
Brake lines can fail 'from the inside'. The outside looks perfect. What happens is the inside fails and collapses. After a trip to a semi repair shop they said bad brake lines it is a common failure on this chassis.
So when your coach is in the shop change the brake lines whether they look bad or not. Also you won't find an aftermarket for them the ONLY ones that will fit are the OEM lines. Had to wait one extra day for the OEM brake lines to be delivered. But worth the wait.
