otrfun's avatar
otrfun
Explorer II
Dec 06, 2016
Brake Line Placement for TT Disc Brakes
Most trailer installation pics and videos I've seen show flex hydraulic brake lines run from the frame rail to the caliper assembly, mere inches from the side of the tire.
On my truck I noticed steel hydraulic brake lines are routed to the middle of the truck (from the frame rail), just above the differential. A flex hydraulic line runs from the steel hydraulic brake line just above the differential to a splitter mounted to the differential itself. The splitter then feeds two steel hydaulic lines which are mounted on (and protected by) the backside of the axle and routed to each caliper assembly.
In terms of protecting the brake line from tire fragments in the event of tire failure, it would seem the method used on my truck would offer much better protection.
Thoughts?
