Gjac
Jun 12, 2019Explorer III
pnichols wrote:Hi Phil, what was you MPG before and after the tire change?
I think that I've improved my motorhome's V10 fuel economy over what is possible with it's 5-speed 5R110W transmission by retrofitting it with non-stock tires that are larger in diameter. Going to a larger diameter tire makes all gears "taller" in any vehicle for improved fuel economy when cruising.
Since our Class C motorhome is a relatively small one for it's E450 chassis, I don't need the extra pulling power that the E450's 4:56 ratio differential provides, so I may as well get some improved mileage through use of larger diameter tires.
An E350 chassis has a 4:12 rear differential ratio, so larger diameter tires on it under a motorhome might make it lug down on hills a bit.
