Gjac
Jun 13, 2019Explorer III
So you just change to a higher aspect ratio tire, sounds like a cheap solution to get greater mpg. I guess if you go too high on the same size rim the MH might have more lean when taking a corner. Do any of the small C's come with larger rim size say 17 or 18 in? I know a lot of the TC guys put larger rim tires in the rear mostly to increase their payload.
38,782 PostsLatest Activity: Sep 10, 2026
