klutchdust
Sep 03, 2015Explorer II
biggjc wrote:
I own a 29' 2010 Winnebago Aspect on Ford E-450 with factory Airbags on the rear. I have not upgraded anything with the exception of a free set of tires courtesy of the Michelin recall. I run with air pressure of 50 psi.
I have been experiencing a lot of rattling,shaking and outright banging whenever I am on less than perfect pavement. Handling is just OK,
I have been lurking on this site for quite some time, and it seems that many of you have replaced your Shocks with the Koni FSB's. I have looked around for pricing and it appears that a set of 4 can be had for about $600 . I'm OK this - but I wonder if there is anything else I should do as long as my rig will be in the shop for installation . My goal is to reduce coach noise and improve handling. Any suggestions?
Just installed Koni's, previous owner installed huge sway bars. Koni's are proving themselves already. I am also going to look into the rear springs. I believe they used way to stiff springs on these E-450's. Unless weighed
down heavy they ride rough. Looking for that sweet spot to put in the airbags. 5 lbs can make a big difference. When I had my 32ft. gooseneck with my jeep inside and water etc, 45lbs on my single wheel Duramax
was great, 5 lbs more and it would bounce you out of the seat.
