LifeInsideJack wrote:
Biggyniner wrote:
So... I have a 1994 Minnie Winnie with the 460 in it. I have an occasional miss at idle, not the same problem you have, but similar in nature. It's had the distributor changed, ford plugs and wires and fuel filter, yet it still persists. I have it in the shop now and I will let you know what they find...
Thank you !
So they have been looking at it for three days and they narrowed it down to two things. Either the ignition control module, or the PCM/ECU. They want a ridiculous amount of money to do the ignition control module. So I will probably start there and do it myself. I've also read that the capacitors, there are 3, can go bad in the PCM. I am going to check those as well (for swelling) and replace them if needed. Do a Google search on ford 460 pcm capacitor leakage for more info.
Hope this helps.
